trial release and ddf import
  • EcoStruxure IT forum
  • trial release and ddf import
125
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 02:40 PM . Last Modified: ‎2024-04-03 11:49 PM
804
Does the DCE trial support the import of DDF (XML)? It does not appear to be working.
(CID:137105270)
  • DDF
Posted: ‎2020-07-05 02:41 PM . Last Modified: ‎2024-04-03 11:49 PM
804
Dear Leigh Sandy,
The DCE software import function of DDF-files should always work.
Please, describe your problem in detail, that you are not able to import DDF-files? Attach a couple of screenshots, please.
With respect.
(CID:137105304)
Replies 4
805
Dear Leigh Sandy,
With respect.
(CID:137105304)
My mistake. It appears to be running as the administrative user, but I am logged in as a standard user. I had to move out of the default Documents folder... Now I see it. It is working.
Thanks for your quick response.
(CID:137108844)
Ok, thanks for the quick feedback.
(CID:137108846)
Posted: ‎2020-07-05 02:41 PM . Last Modified: ‎2023-10-22 09:37 PM
