Posted: 2020-07-02 09:55 PM . Last Modified: 2024-04-09 01:37 AM
I have several LIU's "top" mounted. I would like to be able to see them in the rack view.
For some reason once a device is mounted in top it goes to to 0 U and you can not change it.
How can I get my top mounted LIU's to show up, on the rack view?
(CID:105459701)
Hi Cameron, What does LIU stand for? Can you please add some screen captures to illustrate your model, and steps to reproduce, so I can test it locally, thanks. Kind regards
(CID:105459747)
Hi Cameron,
The same topic is discussed here:
Christian
(CID:105459895)
Posted: 2020-07-02 09:55 PM . Last Modified: 2023-10-31 11:35 PM
