Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-05 03:21 PM . Last Modified: 2024-04-03 11:27 PM
Botz 355
Hi, can I switch periodic reports sent via FTP to SFTP ? If so, how ?
Thank you,
(CID:137111367)
Hi nanoman,
Sorry but there is no hidden setting, the options are ftp, http, or e-mail. On the FTP option, all you get is what you see here:
I would suggest if you feel this is needed that you put in an enhancement request using the "Resources --> Feature Requests" menu.
Steve
(CID:137111396)
Hi Steve, is the a "work around". That is, can I set the transfer mode to passive ? or is there a way to just sent the "graphs" without the .xml file?
(CID:137112394)
Hi nanoman,
Sorry but as I mentioned, what you see is what you get for settings and options. You have the option to include graphs or not but there is no option to NOT send the data. As for active or passive ftp, that would be something that would have to be changed in the back end and I don't know if you'd be able to tweak any config file or if you could, what it might do to the rest of the processes.
Steve
(CID:137112407)
Posted: 2020-07-05 03:22 PM . Last Modified: 2024-04-03 11:27 PM
Steve,
Thanks. Is there a way I can change the data file extension from "xml" to something else?
(CID:137112503)
nanoman, Like I said, the configuration options are all listed.
(CID:137112524)
Thanks Steve. I currently use FTP but would like to use sFTP. It seems like it's a reasonable item to put in a request for.
(CID:137111403)
Is it reasonable to request? Absolutely. Will it make it into the product? That I can not say.
(CID:137112527)
Posted: 2020-07-05 03:22 PM . Last Modified: 2023-10-22 09:36 PM
