sepam integration into DCE
  • sepam integration into DCE
129
72
Posted: ‎2020-07-05 10:07 PM . Last Modified: ‎2024-04-03 12:35 AM
1550
We have Sepam series 40, series 60 in our facility and wish to add them to DCE for remote monitoring. Is this possible? how?
If not what alternative do i have
(CID:148769331)
  • Data Center Operation
1549
Hi!
You need to go to https://ddf.ecostruxureit.com/ page and download DDF file for your device.
Then you should upload that ddf to DCE and run discovery with appropriate IP and slave ID.
Sepam should be connected to the network via Modbus TCP.
(CID:148769405)
Replies 5
1550
Hi!
(CID:148769405)
Dear Kozlov,
Thanks. please advise on possible devices i can use to establish MODBUS TCP/IP.
(CID:148769578)
We usually works with SE's TSXETG100 and Link150 gateways. This devices convert Modbus protocol to ModbusTCP.
(CID:148769582)
Posted: ‎2020-07-05 10:07 PM . Last Modified: ‎2024-04-03 12:34 AM
Thanks for your support. Kozlov
(CID:148769590)
Posted: ‎2020-07-05 10:08 PM . Last Modified: ‎2023-10-22 09:36 PM
