reverse number rack
  • reverse number rack
129
72
Posted: ‎2020-07-03 06:12 PM . Last Modified: ‎2024-04-07 11:57 PM
1225
reverse number rack
My Data center uses 45u 2 & 4 post open racks for our network equipment.  The numbering is reversed, as in 45 is at the bottom, 1 is at the top.  How do we get 2 & 4 post racks added to the genome to accommodate us?
(CID:122692239)
  • Genome
Posted: ‎2020-07-03 06:12 PM . Last Modified: ‎2024-04-07 11:56 PM
Hi Trebor,
The rack numbering can be reversed from version 8.2.1 of DCO.
More information can be found at the bottom of this page: Adding rack-mountable equipment to the room layout
/Søren
(CID:134025599)
Replies 4
Hi Trebor
Search the Genome Library for "post" and use one of the results as the template for your Genomes entry.  Not sure how to reverse U numbering.  If you find out, pls post
Ed
(CID:122692295)
We used the Panduit 2 & 4 post racks from the genome.  Actually, what we have are Panduit 2 & 4 post open racks.  There seems to be no way to reverse the numbering.  I think I may need a StruxureWare Engineer to help with this.   I suspect that when our racks were originally assembled the number guides themselves were reversed.  There are 14 of them and they are full of live equipment so it is not realistic to remove equipment to swap them around.   We either need the ability to change numbering or We need 2 & 4 post racks created that are reversed in numbering.
(CID:122692500)
Hi Trebor,
/Søren
(CID:134025599)
Posted: ‎2020-07-03 06:13 PM . Last Modified: ‎2023-10-22 09:35 PM
