Posted: 2020-07-02 04:33 PM . Last Modified: 2024-04-09 02:45 AM
I can't use the "upload&download" options
How do you do login as "root" in the webmin?
Is it possible to edit "config file" from console (sudo vi config file, user="apc")?
(CID:103585570)
Hi Roberto,
You do not need to modify anything. This is a known issue in Webmin - you are presented with a security warning when opening any popup in IE. (the issue has been reported in http://ehc.ac/p/webadmin/bugs/4427/?limit=25 )
So, as a work around I would suggest to use another browser, such as Firefox or Chrome.
Kind regards
(CID:103585599)
Hi Roberto,
Kind regards
(CID:103585599)
Perfect. Resolved
Kind regards
(CID:103585639)
Excellent, many thanks for sharing, Kind regards
(CID:103585640)
Posted: 2020-07-02 04:34 PM . Last Modified: 2023-10-31 11:33 PM
