Posted: 2020-07-02 04:34 PM . Last Modified: 2024-04-09 02:45 AM
Hi!
Please, help me.
In DCo has function, how find the best Rack for server or dataPanel or another Device.
I want to know, have DCO function "find the best place for RACK in DataCentre"?
for exemple: i have DataCentre, i have 50 rack and i need to place 1 Rack. Where can i place Rack in Datacentre? Can DCO have report or another function for "the best place for RACK in DataCentre" ?
can you recommend another way?
(CID:103585634)
Hi Evgeny,
I believe finding a best place for a rack is not a supported feature, currently the Asset Provisioning would recommend the best location for a server in the rack layout. Following page contains more details: Working with Asset Provisioning
Kind regards
(CID:103585645)
It's abour place for asset. it's clear. There is a report of a load on the floor?It may be a visual REPORT that I saw the load floor?
(CID:103585660)
Hi Evgeny, I'm not aware of a report that could be based on the floor load (I have checked and couldn't find such option). But, I was wondering perhaps it might useful to use Row, sort of room fixture asset (from the Genome Library), then it would be easier to plan the row distance from each other, and or from the surrounding objects or wall. Then the rack(s) can be easily added/moved to a chosen row. Kind regards
(CID:103585664)
Posted: 2020-07-02 04:34 PM . Last Modified: 2023-10-31 10:17 PM
