netbotz 450 send set command
  • netbotz 450 send set command
129
72
Posted: ‎2020-07-03 10:22 PM . Last Modified: ‎2024-04-07 11:06 PM
973
good morning all
is there any way to send a set command to a netbotz 450 to set relais state?
best regards
patrick
(CID:124521784)
  • NetBotz
Replies 4
Hi Patrick,
I've had a look at this myself, and all the sensors seem to be ready only in the iReasoning MIB Browser. However, i might be wrong, so I will let others comment here, just to confirm.
Regards
(CID:124521841)
thank you john, i have seen this and it is possible to read only over web api but i do not find any way to send command. Customer would like to use it to control the lights in dc. Wish you a nice day.
regards
(CID:124521890)
Hi Patrick,
Nope, John is correct, there is no option to use the SNMP SET command in NetBotz. If you want to manually trigger an event, you'll have to use Advanced View software or in some cases, the NetBotz web interface.
Steve
(CID:124522864)
Posted: ‎2020-07-03 10:23 PM . Last Modified: ‎2023-10-22 09:33 PM
