Posted: 2020-07-05 09:27 PM . Last Modified: 2024-04-03 12:48 AM
I need for trial license IT expert. I registered DCE connect to ITE, but i can't get free trial
(CID:147783876)
Download Ecostruxure IT gateway (click on the gateway link in your screenshot) discover your devices
Disconnect your DCE from Ecostruxure IT Expert Administration tab
and add the gateway ID to your Ecostruxure IT Expert account.
(CID:147784205)
Posted: 2020-07-05 09:28 PM . Last Modified: 2024-04-03 12:48 AM
Hello Christopherus
I dont use IT gateway for discover device.But i use DCE
functioned as gateway
(CID:147783885)
(CID:147783888)
You cannot use DCE as gateway for ITE.
(CID:147783891)
but why I can register to ITE and the device discover can appear from inventory ITE
(CID:147783898)
The registration you did with DCE was for Ecostruxure Asset advisor (same page) for remote services, and that can be done via DCE.
You will not be able to see the full ITE features from DCE to Ecostruxure IT such as benchmarking, assesement.
To test out the ITE, you will need to:
1.install the Ecostruxure IT gateway &rediscover devices with gateway,
2.Disconnect DCE from your Ecostruxure IT account
3.Add the gateway to your account
Hope that clarifies.
(CID:147783904)
Hi Rudhi Hardha Lukman,
The IT Expert free trial requires that you use the EcoStruxure IT Gateway. You can use DCE and the Gateway in parallel. Read more here: https://sxwhelpcenter.ecostruxureit.com/display/UADCE725/How+Data+Center+Expert+users+can+connect+de...
Jackie
(CID:147784589)
Posted: 2020-07-05 09:28 PM . Last Modified: 2023-10-22 09:32 PM
