Posted: 2023-04-18 09:29 AM
Good day,
I need to make a network connection of a port with a multifiber connector, I have not found a way to do it.
Is there any way to do it?
that is, port 1 of Switch 1 connects to Port 1,2,3,4,5,6 of Switch 2
Posted: 2023-04-18 12:24 PM
Hello.
The concept/features of fan-out cables (where a single port connection fans out to multiple destinations) was introduced in IT Advisor 9.2.x and is not available in Data Center Operation.
If you are a customer with an active support contract then you are entitled to upgrade to IT Advisor
Regards
Greg Sterling
Hello.
Regards
Greg Sterling
Posted: 2023-04-18 12:28 PM
I understand, thank you very much for the support
