mount error(115)
  • mount error(115)
129
72
Posted: ‎2020-07-04 02:06 PM . Last Modified: ‎2024-04-05 02:44 AM
1012
mount error(115)
(CID:128754954)
  • Data Center Operation
Posted: ‎2020-07-04 02:07 PM . Last Modified: ‎2024-04-05 02:44 AM
Dear Samir ABASSI,
If you are looking for information on the errors of mounting Windows network resources (for example, cifs_mount failed w/return code = -115), then useful information can be found in my answer to the topic :
...According to Linux man page mount (8) this command has the following numbering of exit codes:
RETURN CODES
mount has the following return codes (the bits can be ORed):
0 success
1 incorrect invocation or permissions
2 system error (out of memory, cannot fork, no more loop devices)
4 internal mount bug
8 user interrupt
16 problems writing or locking /etc/mtab
32 mount failure
64 some mount succeeded
I.e., your mount return code -115 is a set of five errors:
112 = 64+32+16+2+1
If you have any further questions, please ask.
With respect.
(CID:128755080)
Hi Samir,
You might want to try the mount type "Common Internet Filesystem (cifs)", that should be included in 8.x offline installations:
Kind regards
(CID:128756662)
Posted: ‎2020-07-04 02:07 PM . Last Modified: ‎2023-10-22 04:42 AM
