link 150 oid / mib files
  • EcoStruxure IT forum
  • link 150 oid / mib files
125
65
Back to EcoStruxure IT forum
Posted: ‎2021-03-03 06:18 AM
2307
I'm in IT so don't really know what i'm talking about re this electric gear to warn you!
Basically we have an ethernet gateway link 150 meter.  with other meters in our business we can get the oid number from the mib library to read the meter using our prtg snmp monitoring software.
Is it possible to get the oid/mib files for a link 150?
If not is the only way to read the power usage to get the v expensive schneider software?
Any help / pointers appreciated.
  • power monitoring expert
Captain
Posted: ‎2021-03-03 06:28 AM . Last Modified: ‎2021-03-03 06:29 AM
2303
Hi @Anonymous user ,
If you're using this:
https://www.se.com/ww/en/product/EGX150/link-150---ethernet-gateway---2-ethernetport---24-v-dc-and-poe/
What you're likely doing is connecting a modbus device on one side and network on the other..
If this is the case, polling the 150 using SNMP will only provide you a little info on the gateway itself and not the connected devices. What this is designed for is to translate Modbus RTU (serial) to modbus over IP.
To monitor the devices through this gateway, you would poll the IP and secondary device(s) using modbus over IP and not using SNMP. The modbus register map would be that of the devices and not specific to the gateway.
Steve
Captain
2304
Steve
Posted: ‎2021-03-03 06:50 AM
In response to APC_Steve
perfect thats a lot clearer thank you
