infrastruxure Central surveillance package needed
  • EcoStruxure IT forum
  • infrastruxure Central surveillance package needed
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 04:24 AM . Last Modified: ‎2024-04-08 11:40 PM
636
Just want to be sure and confirm the following are what I need to get Infrastruxure central to
perform surveillance video capture on netbotz 355's
NetBotz Surveillance Base - 15 Nodes      NBSV1000
NetBotz Surveillance Add On Pack - 25 Nodes
If I need anything else please let me know
Thank you
(CID:106210481)
  • NetBotz
Replies 4
That looks correct. The base license will turn on the Surveillance feature. The add-on packs are for the additional capacity you need.
It should be said that the 355 pods themselves require device licenses if you don't already have those in place.
(CID:106210544)
Posted: ‎2020-07-03 04:25 AM . Last Modified: ‎2024-04-08 11:40 PM
636
Hi Earl,
How many cameras are you adding? Unlike the old NetBot central days, the base 15 surveillance key is not necessary. You can add it and it adds support for 15 cameras but is not required. If you are adding 26 cameras, you only need the 25 surveillance add on.
Steve.
(CID:106210546)
26 or less that is...16 or less to add the 15 pack. 1 is pre installed.
(CID:106210547)
Posted: ‎2020-07-03 04:25 AM . Last Modified: ‎2023-10-31 11:09 PM
