Posted: 2020-07-05 10:51 PM . Last Modified: 2024-04-03 12:20 AM
(CID:149786171)
Posted: 2020-07-05 10:51 PM . Last Modified: 2024-04-03 12:19 AM
Same server? Use Planning–>Asset Provisioning, and select Add Asset to Selected racks
You can then select multiple racks (hold Ctrl when you click the rack) to where the server will be added.
If you need to assigned large amount of multiple different servers to multiple racks at different U space at one go, to different locations, such as initial deployment, do consider excel import.
(CID:149786189)
Ahhh, man that is perfect, worked like a charm. I will search on how tow import from Excel before I ask how to do that haha. But for now, this is a huge help good sir!! Thank you!!
(CID:149786224)
Glad that help 😀
-Revised the initial post to answer.
Have a good day!
(CID:149786220)
Posted: 2020-07-05 10:51 PM . Last Modified: 2023-10-22 04:39 AM
