Share Your Feedback โ Help Us Improve Search on Community! Please take a few minutes to participate in our Search Feedback Survey. Your insights will help us deliver the results you need faster and more accurately. Click here to take the survey
Posted: โ2020-07-05 12:02 AM . Last Modified: โ2024-04-04 01:13 AM
How to regenerate and use an SSL certificate which does not use weak Hash Algorithms
(CID:134035909)
Posted: โ2020-07-05 12:03 AM . Last Modified: โ2024-04-04 01:13 AM
Dear April,
Please describe your question in more detail with a couple of screenshots (if possible). And then you will be helped faster and better ๐.
With respect.
(CID:134035922)
Hi All, spezialist, April
There is an SSL Certificate Signature Colllision Vulnerability (CVE-2004-2761) identified with the server in question.
April is trying to get a workaround unless we have a release coming out soon that will resolve this issue. See vulnerability document attached Vulnerability Reference - Schneider server.pdf.
(CID:134036508)
Dear Kevin Kolobe,
The above information refers to the free EcoStruxure IT Gateway software?
With respect.
(CID:134036512)
Hi spezialist,
The End User does not have the EcoStruxure IT Gateway as yet. They are only running DCE 7.5.0
(CID:134036520)
Ok, in any case, thanks for the feedback.
(CID:134036560)
Kevin,
Suggest using paid certificate from certificate authority?
Follow steps on generating the CSR from DCE, get it generated thru certificate authjority
Then replace the self signed certificate inside DCE following steps:
(CID:134678267)
Dear April,
Tell us, please, did you solve your question or not?
With respect.
(CID:134679957)
Posted: โ2020-07-05 12:04 AM . Last Modified: โ2023-10-22 04:38 AM
Youโve reached the end of your document
