Posted: 2020-07-02 04:53 PM . Last Modified: 2024-04-09 02:39 AM
Hi guys,
I can't find a way to export the room configuaration (rack, asset IT, power path, networking...) in a excel file format. I don't see the tab in the "file->export" menu.
Shall I introduce something into the config.ini file?
Roberto
(CID:103586223)
Hi Rumi,
Export to Excel is not available in Data Center Operation. You should be able to see other ways of exporting in the file menu. If you don't it might be because of user privileges.
Jesper
(CID:103586227)
Could a possible work-around be to export some of the equipment by using the equipment browser?
(CID:103586232)
Posted: 2020-07-02 04:53 PM . Last Modified: 2023-10-31 11:05 PM
