Export of ll cable connections/route from DCO
  • EcoStruxure IT forum
  • Export of ll cable connections/route from DCO
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 04:53 PM . Last Modified: ‎2024-04-09 02:39 AM
684
Hi. I woudld like to ask you if there exist an option to export (to *.XLS for example) all cable connections from StruxureWare Data Center Operation. Which measn all rack-devices: servers/switches/patch-panel/PDU/... connections. Thank you for your support.
(CID:103586248)
  • Data Center Operation
Replies 4
Posted: ‎2020-07-02 04:54 PM . Last Modified: ‎2024-04-09 02:39 AM
Hi Petr,
Yes, it it possible to export the network configuration to CSV files.
You need to go to the management tab, select the racks and then click the icon  in the opt right corner.
This will give you access to export the network configuration.
Jesper
(CID:103586252)
Hi Petr,
you might want to try the export/export table feature as illustrated:
(CID:103586256)
Thank you so much for your support and fast respond.
Petr Riha
(CID:103586364)
Posted: ‎2020-07-02 04:54 PM . Last Modified: ‎2023-10-31 10:58 PM
