how to disable door sensor in netbotz 250?
  • how to disable door sensor in netbotz 250?
129
72
Posted: ‎2020-07-04 09:01 PM . Last Modified: ‎2024-04-04 03:59 AM
1322
can i disable the door sensor in Netbotz 250?
Minh
(CID:132670688)
  • NetBotz
Posted: ‎2020-07-04 09:01 PM . Last Modified: ‎2024-04-04 03:58 AM
1322
Hi Minh,
If all you want to do is disable the alerting for a door sensor, click the listing for "More" off to the right of door sensors on the home page. Then click the specific sensor you're concerned about. Next, just uncheck enabled:
If the device is alerting through DCE, you can set schedules for alarming for the threshold itself and in the specific alarm profiles. As spezialist noted however, you'll want to be more specific about your requirement if you need a more indepth configuration.
Steve
(CID:132670865)
Replies 4
Dear Minh Pham,
Please clarify your question/problem and, if possible, provide explanatory screenshots. And then you will be helped here faster and better 😀.
With respect.
(CID:132670711)
1323
Hi Minh,
Steve
(CID:132670865)
Hi Steven,
Thanks for quick respond and very clear answered. I could not see the page as you mentioned. However, the error is fixed after re-loaded firmware 6.5.6.
Minh
(CID:132671108)
Posted: ‎2020-07-04 09:01 PM . Last Modified: ‎2023-10-22 04:37 AM
