how to add custom units
  • EcoStruxure IT forum
  • how to add custom units
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 05:24 PM . Last Modified: ‎2024-04-08 12:13 AM
827
How to add custom units for ddf?
For example: resistance (Ω), capacitance (F)......
and, can  add loops in DDF?
I have a MODBUS device, many of which are repetitive.
for example
MonomerVoltage Group 01 address: 10000~10500
MonomerVoltage Group 02 address: 14000~14500
I want to compress these
(CID:122094325)
  • DDF
Replies 5
Hi Guanyc,
I don't recommend editing the DDF files yourself. I have seen DDFs edited outside of the DDF team that have caused DCE to have issues up to and including failure to boot. If this happens, it is likely the only workaround will be to restore the system.
I suggest requesting a DDF or DDF edit through the device support menu above.
Steve
(CID:122094592)
Hi guanyc,
Unfortunately, the DCE-server in the list of standard predefined units does not have the above-mentioned radio engineering values. The only such unit of measurement is microSiemens/cm (conductivity).
Therefore, in my practice, I simply add a unit of measurement to the label of the sensor, for example:
xmlDDF examplenum
This is the easiest and fastest way to add a specific custom unit of measurement.
I will be glad to answer the questions.
(CID:122095412)
(CID:122691247)
I will be glad to answer the questions 😀.
(CID:122691253)
Posted: ‎2020-07-03 05:24 PM . Last Modified: ‎2023-10-22 04:37 AM
This is a heading
