how do you mount a server horizontally
  • EcoStruxure IT forum
  • how do you mount a server horizontally
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 10:57 PM . Last Modified: ‎2024-04-05 05:02 AM
985
I have a Proliant ML310e G8 V2 and I cannot work out how to rotate it so that it sits on a shelf horizontally so it uses up 4U rather than vertically taking up 8U.
Is this possible?
(CID:124525536)
  • Data Center Operation
985
You can create custom genome for your server. Copy existing genome in to a new and swap width and height. You probably have to maintain two genomes - vertical and horizontal.
See this video:
(CID:124525554)
Replies 4
986
See this video:
(CID:124525554)
And don't forget to adjust mounting options e.g  add "shelf" to mounting options.  Not sure if this is covered in n video.  Then add shelf/s to custom genomes
(CID:124525563)
Thank you. That was helpful information.
(CID:125208402)
Posted: ‎2020-07-03 10:57 PM . Last Modified: ‎2023-10-22 04:36 AM
