how configure New Schneider AM cooling into StruxureWare central?
  • how configure New Schneider AM cooling into StruxureWare central?
129
72
Posted: ‎2020-07-02 11:48 AM . Last Modified: ‎2024-04-10 12:05 AM
561
i have an issue,
i will configure the snmp comunities into the uniflair amico (carel plc), but i can't see the sensors in the  Struxureware central console.
can anyone have a tip for this issue?
(CID:96043260)
  • DCIM Support
Fausto,
You may have already solved this , but you will also need to ensure you have the correct DDF loaded into DCE.  You can reach out to multivendorsupport@schneider-electric.com to see if one already exists and if one doesn't then there is a process by which you can fill out a form to have one create.  Hope this helps
(CID:96043378)
Posted: ‎2020-07-02 11:48 AM . Last Modified: ‎2023-10-31 11:01 PM
