dce client can't connect to server
  • EcoStruxure IT forum
  • dce client can't connect to server
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 12:34 PM . Last Modified: ‎2024-04-09 11:48 PM
755
we found interesting situation with DCE client 7.2.6-24.
When connecting to datacenter via VPN from computer #1 I've got ip address (for example x.x.x.10).
Then I launch DCE client and successfully connecting to DCE server.
Then I close DCE client, disconnect VPN on computer #1,and connect VPN on computer #2 with same credentials and got same ip address x.x.x.10. Download and install DCE client, run it and try to connect to the same DCE server and here I got error message: "Either the address specified is an invalid address, or the connection timeout. Enter a valid hostname/ip address, or increase the connection timeout and try again." Increasing timeout as proposed is nothing.
Ports 80, 443 are opened, firewall on computer #2 is completely disabled. Test connection via telnet to 80,443 ports on server are ok.
.log file in "C:\Users\\.isxc\7.2.6\.metadata" on computer #2 is absent.
actual nbc.xml from server:
5/12/15 08:51:25.356 INFO - StruxureWare Data Center Expert server version: 7.2.6 5/12/15 08:51:25.356 INFO - StruxureWare Data Center Expert server model: VIRTUAL 5/12/15 08:51:25.356 INFO - StruxureWare Data Center Expert server build: 24 5/12/15 08:51:25.356 INFO - StruxureWare Data Center Expert GUI minimum version: 7.2.6 5/12/15 08:51:26.376 INFO - Starting StruxureWare Data Center Expert 5/12/15 08:51:26.972 INFO - Dynamic root password has been set. 5/12/15 08:51:27.102 INFO - Loading Operating System information 5/12/15 08:51:27.104 INFO - Loading Modules.... 5/12/15 08:51:27.165 WARN - log4j:WARN No appenders could be found for logger (org.springframework.context.support.ClassPathXmlApplicationContext). (com.netbotz) 5/12/15 08:51:27.166 WARN - log4j:WARN Please initialize the log4j system properly. (com.netbotz) 5/12/15 08:51:32.692 INFO - Initializing connections to the database... 5/12/15 08:51:32.788 INFO - Database connections initialized 5/12/15 08:51:33.152 INFO - mxBeanName: IsxcQueues:name=EventServiceWorkQueue 5/12/15 08:51:33.227 INFO - mxBeanName: IsxcQueues:name=EventQueueThread 5/12/15 08:51:33.754 INFO - mxBeanName: IsxcQueues:name=ACULQueuedefault 5/12/15 08:51:33.763 INFO - mxBeanName: IsxcContextListeners:name=default 5/12/15 08:51:33.923 INFO - Varlib Initializer start 5/12/15 08:51:34.475 INFO - Varlib Initializer stop 5/12/15 08:51:34.491 INFO - mxBeanName: IsxcQueues:name=VarLibPersisterWorker 5/12/15 08:51:34.508 INFO - (ISXC) Initialized 5/12/15 08:51:34.530 INFO - mxBeanName: IsxcQueues:name=ACULQueueISXC 5/12/15 08:51:34.530 INFO - mxBeanName: IsxcContextListeners:name=ISXC 5/12/15 08:51:34.592 INFO - IP Interfaces loaded 5/12/15 08:51:34.605 INFO - private network settings loaded 5/12/15 08:51:34.620 INFO - NetworkService started 5/12/15 08:51:35.540 INFO - mxBeanName: IsxcQueues:name=RepositoryJobRunnerQueue 5/12/15 08:51:35.647 INFO - mxBeanName: IsxcQueues:name=RepositoryEventQueueThread 5/12/15 08:51:35.802 INFO - Starting repository Local 5/12/15 08:51:36.240 INFO - mxBeanName: IsxcQueues:name=CustomPropertyCleanupQueueWorker 5/12/15 08:51:36.443 INFO - DeviceGroupVarLibVerifier init 5/12/15 08:51:39.762 INFO - mxBeanName: IsxcQueues:name=EnclosureListenerImpl 5/12/15 08:51:39.769 INFO - EnclosureListener Initialized 5/12/15 08:51:39.821 INFO - mxBeanName: IsxcQueues:name=SensorQProcessorRunnable 5/12/15 08:51:39.829 INFO - SensorListener Initialized 5/12/15 08:51:39.878 INFO - SensorSetListener Initialized 5/12/15 08:51:42.793 INFO - Repository Local started, configured max capacity is 4.0 GB 5/12/15 08:51:43.789 INFO - mxBeanName: IsxcQueues:name=EventLogApplicationWorker 5/12/15 08:51:43.964 INFO - EnclosureListInit Initialized 5/12/15 08:51:44.687 INFO - mxBeanName: IsxcQueues:name=AlertServiceFilterQueue 5/12/15 08:51:44.937 INFO - Device Control Service Initializing... 5/12/15 08:51:45.323 INFO - mxBeanName: IsxcQueues:name=ThresholdingUpdateQueue 5/12/15 08:51:45.330 INFO - mxBeanName: IsxcQueues:name=ThresholdingCreateQueue 5/12/15 08:51:45.352 INFO - mxBeanName: IsxcQueues:name=ThresholdingDeleteQueue 5/12/15 08:51:48.570 INFO - Initializing threshold service 5/12/15 08:51:48.651 INFO - (completed in 0.06 seconds) 5/12/15 08:51:48.961 INFO - AlertListener Initialized 5/12/15 08:51:49.468 INFO - ModbusSlaveServiceImpl Initializing... 5/12/15 08:51:50.311 INFO - mxBeanName: IsxcQueues:name=Snmp4jTrapSenderQueue 5/12/15 08:51:50.620 INFO - mxBeanName: IsxcQueues:name=NMSAlertEventProcessorQueue 5/12/15 08:51:50.629 INFO - NMSServiceImpl Initialized... 5/12/15 08:51:50.715 INFO - PrivateProxyServiceImpl Initialized. 5/12/15 08:51:51.235 INFO - Using rms-api.properties located at:/com/netbotz/server/services/rms/impl/properties/ 5/12/15 08:51:51.818 INFO - mxBeanName: IsxcQueues:name=SensorCollectingQueueWorker 5/12/15 08:51:52.156 INFO - mxBeanName: IsxcQueues:name=DeviceCompositeEventProcessor 5/12/15 08:51:52.224 INFO - ProxyService started (socks proxy server running: false) 5/12/15 08:51:52.241 INFO - HttpProxyService Initializing... 5/12/15 08:51:52.253 INFO - Disabling http proxy settings... 5/12/15 08:51:53.734 INFO - SearchLib.init 5/12/15 08:51:53.749 INFO - Search Service Initializing... 5/12/15 08:52:00.829 INFO - PolicyListenerImpl: cache constituted in 9 milliseconds 5/12/15 08:52:00.829 INFO - mxBeanName: IsxcQueues:name=PolicyListenerImplEnclosureWorker 5/12/15 08:52:00.834 INFO - mxBeanName: IsxcQueues:name=PolicyListenerImplAlertProfileWorker 5/12/15 08:52:01.037 INFO - Mapped 0 identifiers in 3 milliseconds. 5/12/15 08:52:01.369 INFO - Synchronization completed in 0.3 seconds. 5/12/15 08:52:01.369 INFO - (20 updated, 0 deleted, 20 validated) 5/12/15 08:52:01.428 INFO - mxBeanName: IsxcQueues:name=ThresholdDriverEventWorker 5/12/15 08:52:01.449 INFO - mxBeanName: IsxcQueues:name=ThresholdingSensorDriverQueue 5/12/15 08:52:01.489 INFO - mxBeanName: IsxcQueues:name=ThresholdingEnclosureDriverQueue 5/12/15 08:52:01.586 INFO - mxBeanName: IsxcQueues:name=ExposedAlarmProcessorExposedAlarmSetWorker 5/12/15 08:52:02.416 INFO - Initializing Campus Manager service 5/12/15 08:52:03.827 INFO - mxBeanName: IsxcQueues:name=VirtualSensorFSMEventQueue 5/12/15 08:52:03.827 INFO - mxBeanName: IsxcQueues:name=VirtualSensorFSMDelayedEventQueue 5/12/15 08:52:04.702 INFO - mxBeanName: IsxcQueues:name=CustomSensorSensorDriverQueue 5/12/15 08:52:04.719 INFO - mxBeanName: IsxcQueues:name=CustomSensorEnclosureDriverQueue 5/12/15 08:52:06.324 INFO - PluginsManager initialized 5/12/15 08:52:14.885 INFO - mxBeanName: IsxcMaster:name=IsxcJmxMaster 5/12/15 08:52:14.904 INFO - Server configured to use a maximum of 455.0 MB of memory with 1 CPUs. 5/12/15 08:52:14.904 INFO - StruxureWare Data Center Expert Startup Complete 5/12/15 08:52:15.026 WARN - Not able to send email since the settings are not complete. (com.netbotz.server.services.email.impl.EmailServiceImpl) 5/12/15 08:52:21.731 INFO - User [apc] [7C2F1CA68FBD7F92B88D367AA30A71C0] logged in 5/12/15 08:52:25.397 INFO - Surveillance is licensed for 1 devices 5/12/15 08:52:37.590 INFO - Registering event session: 70e2ddd8-6327-4593-a8d5-ab310e9b88b9 5/12/15 08:52:37.592 INFO - mxBeanName: IsxcQueues:name=RestEventProcessor 5/12/15 08:52:37.592 INFO - Adding observers: 70e2ddd8-6327-4593-a8d5-ab310e9b88b9 5/12/15 08:52:48.520 INFO - updateSubscription event session: 70e2ddd8-6327-4593-a8d5-ab310e9b88b9 5/12/15 08:52:48.520 INFO - Adding observers: 70e2ddd8-6327-4593-a8d5-ab310e9b88b9 5/12/15 08:53:17.339 INFO - updateSubscription event session: 70e2ddd8-6327-4593-a8d5-ab310e9b88b9 5/12/15 08:53:21.633 INFO - updateSubscription event session: 70e2ddd8-6327-4593-a8d5-ab310e9b88b9 5/12/15 08:53:21.633 INFO - Adding observers: 70e2ddd8-6327-4593-a8d5-ab310e9b88b9 5/12/15 08:54:56.959 INFO - User [apc] [7C2F1CA68FBD7F92B88D367AA30A71C0] logged out 5/12/15 08:55:12.522 INFO - User [bii] [6DDF3C75B3655CC29EE2A50F357F5297] logged in 5/12/15 08:55:29.109 INFO - User [bii] [6DDF3C75B3655CC29EE2A50F357F5297] logged out 5/12/15 08:56:19.643 INFO - Registering event session: 91601e75-9952-47b0-8d01-c64f35962642 5/12/15 08:56:19.643 INFO - Adding observers: 91601e75-9952-47b0-8d01-c64f35962642 5/12/15 08:56:25.286 INFO - updateSubscription event session: 91601e75-9952-47b0-8d01-c64f35962642 5/12/15 08:56:25.286 INFO - Adding observers: 91601e75-9952-47b0-8d01-c64f35962642 5/12/15 08:57:56.136 INFO - User [apc] [DDAB1238E3C1116FCB3163653CC30C71] logged in 5/12/15 09:02:26.787 INFO - User [apc] [DDAB1238E3C1116FCB3163653CC30C71] logged out 5/12/15 09:02:37.596 WARN - Session 91601e75-9952-47b0-8d01-c64f35962642 was timed out (com.apc.isxc.event.application.RestEventApplication) 5/12/15 09:02:37.596 INFO - Unregister event session: 91601e75-9952-47b0-8d01-c64f35962642 5/12/15 09:06:54.323 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:11:28.425 INFO - Registering event session: d45d61d3-12c2-400a-9e98-08c4049a3828 5/12/15 09:11:28.425 INFO - Adding observers: d45d61d3-12c2-400a-9e98-08c4049a3828 5/12/15 09:11:34.030 INFO - updateSubscription event session: d45d61d3-12c2-400a-9e98-08c4049a3828 5/12/15 09:11:34.030 INFO - Adding observers: d45d61d3-12c2-400a-9e98-08c4049a3828 5/12/15 09:11:54.995 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:11:59.982 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:16:55.082 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:20:37.597 WARN - Session d45d61d3-12c2-400a-9e98-08c4049a3828 was timed out (com.apc.isxc.event.application.RestEventApplication) 5/12/15 09:20:37.597 INFO - Unregister event session: d45d61d3-12c2-400a-9e98-08c4049a3828 5/12/15 09:20:46.591 INFO - Registering event session: 9b2d40bf-1267-4a3c-ae7b-f50a10c46fa1 5/12/15 09:20:46.591 INFO - Adding observers: 9b2d40bf-1267-4a3c-ae7b-f50a10c46fa1 5/12/15 09:20:52.274 INFO - updateSubscription event session: 9b2d40bf-1267-4a3c-ae7b-f50a10c46fa1 5/12/15 09:20:52.274 INFO - Adding observers: 9b2d40bf-1267-4a3c-ae7b-f50a10c46fa1 5/12/15 09:21:53.761 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:24:33.492 INFO - User [apc] [C64DDB27249521EDF065D1C0C8C1E9FF] logged in 5/12/15 09:24:41.261 INFO - updateSubscription event session: 70e2ddd8-6327-4593-a8d5-ab310e9b88b9 5/12/15 09:26:53.404 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:28:24.290 INFO - User [apc] [C64DDB27249521EDF065D1C0C8C1E9FF] logged out 5/12/15 09:30:37.598 WARN - Session 9b2d40bf-1267-4a3c-ae7b-f50a10c46fa1 was timed out (com.apc.isxc.event.application.RestEventApplication) 5/12/15 09:30:37.598 INFO - Unregister event session: 9b2d40bf-1267-4a3c-ae7b-f50a10c46fa1 5/12/15 09:31:53.602 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:31:57.613 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:34:46.151 INFO - User [bii] [7364F1EDC4499F42FE735A34A895FC4D] logged in 5/12/15 09:36:50.408 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:41:54.646 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:46:54.245 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:47:28.084 INFO - User [bii] [7364F1EDC4499F42FE735A34A895FC4D] logged out 5/12/15 09:49:40.534 INFO - Registering event session: a899756a-1424-4ab4-8b9a-026b57bfc340 5/12/15 09:49:40.534 INFO - Adding observers: a899756a-1424-4ab4-8b9a-026b57bfc340 5/12/15 09:49:46.117 INFO - updateSubscription event session: a899756a-1424-4ab4-8b9a-026b57bfc340 5/12/15 09:49:46.118 INFO - Adding observers: a899756a-1424-4ab4-8b9a-026b57bfc340 5/12/15 09:51:54.731 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:51:59.726 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier) 5/12/15 09:56:37.599 WARN - Session a899756a-1424-4ab4-8b9a-026b57bfc340 was timed out (com.apc.isxc.event.application.RestEventApplication) 5/12/15 09:56:37.599 INFO - Unregister event session: a899756a-1424-4ab4-8b9a-026b57bfc340 5/12/15 10:06:57.103 WARN - FAILED TO TRANSMIT ALERT https://10.136.136.82:443/isxo/core/monitoring/central/AlarmEventReceiver org.soda.dpws.fault.DPWSFault: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target (com.apc.dpws.ISXCentralEventingNotifier)
(CID:96764334)
Hi Alex,
I have seen issues with VPN connections in the past. Just the fact that server #1 is able to access the DCE server shows that the server itself is accepting incoming connections and is working as designed. I'm also assuming that if you connect to the DCE server with any local system, you'll be able to access DCE as well.
I have also seen where if you do not connect to a server, no .metadata/.log file will be created. The same thing will happen if you type in an incorrect IP. Server #2 simply can't access it. Have you also tried launching a browser from server #2? Since we're just using http (or HTTPS depending on your settings) the browser should have similar connections. If we're not connecting, the nbc.xml will not show anything from this failed connection.
You noted that the firewall has been turned off but have you also turned off any antivirus? I've seen antivirus stop specific apps from connecting over the network. Additionally, routers also have firewalls so there could be something on the network blocking it as well.
If you run a packet capture on the DCE segment (mirror the port or put DCE and a laptop on a hub) My guess is that DCE is not seeing any packets from the server #2. you'll need to disconnect server #1 for such a test as you noted they're getting the same IP. If as I suspect we're not seeing any packets from server #2, you'll need to address this in your networking and there's little we can do to help.
Steve
(CID:96764338)
Posted: ‎2020-07-02 12:34 PM . Last Modified: ‎2023-10-31 10:25 PM
