Posted: 2020-07-03 04:23 AM . Last Modified: 2024-04-08 11:40 PM
I have a user who reported the text on the racks in the floor view of a room appears crowded. I pasted an example below.
When I view the room, the text I see is not nearly as crowded as the screenshot. Could this be related to fonts or other display settings?
On my DCO client here is the same row.
(CID:106210472)
Posted: 2020-07-03 04:24 AM . Last Modified: 2024-04-08 11:40 PM
Hi Greg!
On Win7 check text size in "Control Panel\All Control Panel Items\Display" section. I have similar issue when text was set as "Larger". It will looks fine if you choose smallest size.
(CID:106210580)
Hi Greg,
I think you are right, it is not controlled by DCO, but it seems it has something to do with the client workstation fonts & display settings.
For example, I could see some influence on my displayed text when changing the fonts in "Windows Color and Appearance" (Win. 7, Control Panel>All Control Panel Items>Personalization>Windows Color and Appearance, "Advanced appearance...")
Kind regards
(CID:106210521)
I will follow-up with the user to see if changing their windows desktop fonts has a positive effect.
(CID:106210532)
Hi Greg!
(CID:106210580)
Posted: 2020-07-03 04:24 AM . Last Modified: 2023-10-31 10:22 PM
