create internal db
  • create internal db
129
72
Posted: ‎2020-07-02 10:25 AM . Last Modified: ‎2024-04-10 12:54 AM
1148
create internal db
I'm currently unable to create internal db for ETL with Webmin console. "Create" button inactive. Are there any special requirements?
(CID:93914910)
  • Data Center Operation
Replies 7
The only requirements I can think of are that the fields are filled out correctly. The mandatory fields are: Configuration name, Database name, Username and Password.
Please also notice the small orange icons indicating that a field is not filled out correctly.
(CID:93914920)
1148
are there any restrictions for database  and user name, since the "orange icons" don't dissapear with the following definitions:
database name:  export_dco_export
username:           etluser_dco_export
(CID:93914929)
Which version of StruxtureWare Operations are you on? In versions before 7.4.5 it could be possible to get the page in a state where it was difficult to get the create button to be enabled. Can you perhaps upload a screenshot of when you expect the button to be enabled?
(CID:93914956)
Posted: ‎2020-07-02 10:25 AM . Last Modified: ‎2024-04-10 12:53 AM
1148
Current version: 7.4.0
(CID:93914962)
I have looked into the issue and cannot reproduce it here. I will contact you directly to try and solve the issue.
(CID:93914966)
Posted: ‎2020-07-02 10:26 AM . Last Modified: ‎2024-04-10 12:53 AM
The issue originated in the use of Internet Explore 9 which our Webmin module does unfortunately not support fully. The suggested work-a-round is a newer version of Internet Explorer or another browser.
(CID:93914976)
Posted: ‎2020-07-02 10:26 AM . Last Modified: ‎2023-10-31 10:22 PM
