chiller TRAF2042A/1742A
  • chiller TRAF2042A/1742A
126
65
Gabi
Lieutenant Gabi
Lieutenant
Posted: ‎2023-04-01 11:00 AM . Last Modified: ‎2025-04-17 06:52 AM
1
1139
Hi all,
there is any chance to find modbus/snmp documentation for some old chillers TRAF series?
in the past a site was available with all kind of files
snmp/modbus DDF allocated for this kind of models which is named uniflair_aquascroll_SNMP_chiller but does not have defined some sensors. I need to read remotely via DCE sensors regarding inlet/outlet water pressure
Will be easier to integrate via snmp  but seems like snmp walk is endless....counting 12k oid?!?! also tried with mib browser but still running after 15min
thanks
  • DDF
  • IT Expert
Admiral
Posted: ‎2024-05-05 06:38 PM
Hi @Gabi,
I recommend reaching out to technical support if you still require these MIB files to find the values you are searching for.
Cory
Admiral
Hi @Gabi,
Cory
