best places for NetBotz 200/150 sensors
  • best places for NetBotz 200/150 sensors
127
65
Posted: ‎2020-07-03 03:29 AM . Last Modified: ‎2024-04-08 11:57 PM
958
could you please guide me how and where to place humidity / temperature sensors within Data Center RACKS. I have two InRow RP and InRow RD units?
(CID:106206329)
  • NetBotz
Dear Abdullah,
Here are the recommendations to install a temperature sensor(AP9335T) at the racks.
  1. Attach sensor to the door of a rack using wire clips (top graphic). Do not apply the wire clips directly on the sensor.  Attach sensor to the vertical rail in a rack using adhesive cable tie holders and tie            wraps (bottom graphic). Do not apply tie  wraps directly on the sensor.
        2. Connect the sensor cable to  a Universal Sensor Port on a  compatible device. The length                               can be extended via an RJ-45 coupling with CAT-5 cable.
Here are the recommendations to install a temperature and humidity(AP9355TH) sensor at the racks.
  1. Attach sensors to the door of a rack using a  housing clip and wire clips (top graphic).                                  Make sure the housing clip snaps around the sensor’s top recessed channel.
      Attach sensors to the vertical rail in a rack using  adhesive cable tie holders and tie wraps (bottom         graphic). Tighten a tie wrap across the sensor’s bottom recessed channel.
    I also suggest you to refer the APC APC Whitepaper #102: Monitoring Physical Threats in the Data Center for more useful information.
I hope this helps.
Bala
(CID:106206341)
Posted: ‎2020-07-03 03:29 AM . Last Modified: ‎2023-10-31 10:17 PM
