Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-03 12:21 AM . Last Modified: 2024-04-09 12:57 AM
Hi, is there any way to meassure or report availability of a variable. I mean, need to know the "uptime" of energy provider using DCE.
Thanks in advance
Martin
(CID:105466835)
Hi mmiodosky, thank you for posting! Let's see who can provide insights to this. @community - any ideas? Best, Stine
(CID:105467297)
Hi Martin,
I had held off on answering this as I had hoped something within DCO such as energy efficiency or PUE could somehow be leveraged for something like this. Since I've seen no answer, I'm guessing it can not.
Within DCE, there is no way to define the % of availability in a specific sensor. You can run reports and using that data outside of DCE, can create an Excel sheet or graph to see what sensors may have gone unplugged but I know of no direct way within DCE to measure what you're looking for.
Sorry,
Steve.
(CID:105468233)
Hi mmiodosky You can not add new reports to DCE and you can only report on sensor values. Nor can do calculations with sensor values. Maybe you can elaborate a little on your question? Maybe give us an example of what you are trying to accomplish. This will help us give you a better answer. Thanks Jesper
(CID:105468287)
Posted: 2020-07-03 12:22 AM . Last Modified: 2023-10-31 10:16 PM
