PUE/DCIE Dashboard Not Available
  • PUE/DCIE Dashboard Not Available
126
65
Posted: ‎2020-07-03 12:20 AM . Last Modified: ‎2024-04-09 12:57 AM
706
Hi Community,
I have just configured and estimate PUE value, but i still can not see PUE dashboard. Sorry for that but i can not find in DCO user manual how i can see. Should i wait for midnight or should i create a web service?
DCO server web interface has an error message which is attached.
Regards
Kerem
(CID:105466674)
  • Data Center Operation
Replies 5
706
Dear Kerem,
The PUE/DCiE dashboard which you are referring need to be configured under Planning–>PUE/DCiE Configuration.
There is a Video Tutorial available to configure simple PUE/DCiE dashboard.
How to setup PUE or DCiE dashboard
Bala
(CID:105466688)
Posted: ‎2020-07-03 12:21 AM . Last Modified: ‎2024-04-09 12:57 AM
Hi Balaraman, I just create and estimate the system which is in videos. But can not see the dashboard tag in Analytics. You can check link case below. http://dcimsupport.apc.com/questions/105459899/answers/105459901/comments/105466520 Thank you Kerem
(CID:105466724)
Dear Kerem, Do you still not able to see the PUE dashboard? Are you referring to Simple PUE dashboard or Energy Efficiency PUE calculation? A Simple PUE dashboard should appear after you follow the Vidoe tutorial instructions. I would suggest you to make sure that Power IN and IT Load values are correctly saved and shown.
(CID:105467090)
Hi Balaraman Jagadeesan I can not still see the PUE dashboard on Analytics. As you can see images in attached. Please can you advice me how to fix.. Regards Kerem
(CID:105467309)
Posted: ‎2020-07-03 12:21 AM . Last Modified: ‎2023-10-31 11:31 PM
