Posted: 2020-07-04 01:34 AM . Last Modified: 2024-04-05 04:05 AM
I'm using cxf2.7 as the client to call Web Service: the code for initializing device service is as follows:
Map
Properties.put ("mtom-enabled", Boolean.TRUE); //$NON-NLS-1$
Factory.setProperties (properties);
Factory.setServiceClass (ISXCentralDeviceServiceV20.class);
String url = "http://xxip/integration/services/ISXCentralDeviceService_v2_0"";
Factory.setAddress (URL); //$NON-NLS-1$//$NON-NLS-2$
Factory.setUsername ("APC");
Factory.setPassword ("APC");
ISXCentralDeviceServiceV20 serviceV20 = factory.create (ISXCentralDeviceServiceV20.class);
This method can be passed directly in the main method, but integrated into the spring, but not through the front-end URL call, run to factory.create (ISXCentralDeviceServiceV20.class) error reporting,
Error message: org.apache.cxf.bus.extension.ExtensionException: Could not create object of extension class org.apache.cxf.wsdl11.WSDLManagerImpl.
I don't know why, I don't know whether it's the package or spring. Thank you for your advice. Thank you!
(CID:126171430)
Hi ly, thanks for posting. Sorry to hear you're having trouble. Let's hope you find your answer here.
Kind regards
Ditte
(CID:126173333)
Hi ly,
I'm sorry you didn't find an answer to your question here. I'm going to close this question now. If you still have an issue, please feel free to post a new quesiton.
Stine
(CID:130681749)
Posted: 2020-07-04 01:34 AM . Last Modified: 2023-10-22 04:24 AM
