Posted: 2020-07-03 08:44 AM . Last Modified: 2024-04-08 03:46 AM
In the web client for DCO, can any hyperlinks (URL's) added via custom properties be 'active' or clickable? At the moment the text needs cutting and pasting out into a new browser window. This feature would make it easier to use particularly on mobile devices in the DC.
(CID:110006962)
Hi Nigel,
Currently DCO web client doesn't support hyperlinks configured in custom properties to be clickable/active. I will go ahead and capture this as a feature request for you, thanks.
Kind regards
(CID:110006969)
I would also be keen to see this feature added.
Has there been any movement on this?
(CID:118004171)
Hi Chad,
I've just tested this on DCO 8.1 and can see the web client is now supporting hyperlinks.
Kind regards
(CID:118004494)
Great to hear, ill be doing the upgrade soon and look forward to getting them working.
(CID:118004754)
Posted: 2020-07-03 08:44 AM . Last Modified: 2023-10-22 04:23 AM
