Wireless NetBotz 250 temperature sensors not showing on DCO 3D model?
  • Wireless NetBotz 250 temperature sensors not showing on DCO 3D model?
127
65
Posted: ‎2020-07-04 10:34 PM . Last Modified: ‎2024-04-04 02:50 AM
1317
 Hi Team,
I've recently encountered an issue, i want to map temperature(wireless sensors) values on DCO, i did the association as desired.
 As you can see the association is done:
Association showing to be okay
My 3D model doesnt map out the measured values. what might be the cause of this?
Please assist
Regards
 Thabo
(CID:134025172)
  • Data Center Operation
  • DDF
  • NetBotz
1318
Hi Thabo,
As illustrated, perhaps your cooling plan is on "Nothing" or "Calculated plan":
Temperature sensors should appear when/if we switch to "Measured plan":
Kind regards
(CID:134025208)
Replies 8
1319
Hi Thabo,
Kind regards
(CID:134025208)
Hi Jef,
That is not the case,  think it might have to do with the firmware of the sensors
(CID:134025487)
Hi Thabo,
But according your 2D screen-shoot, it seems the temperature sensor data is being displayed in DCO.
Kind regards
(CID:134025530)
Hi Jef,
The sensors are there on the 2D model, but on the 3D nothing shows up.
Note: I'm Using a Netbotz 250
(CID:134026285)
Posted: ‎2020-07-04 10:35 PM . Last Modified: ‎2024-04-04 02:50 AM
Hi Thabo,
I've been running several tests since yesterday without any problem, wondering if it is possible to ask for a copy of your backup file so I can test it locally? I will send you an invite to my =S= box, so the data safely can be shared with me (if you would), thanks.
Kind regards
(CID:134026948)
Hi I finally found my mistake, i discovered the Netbotz 250 as instead of SNMP. 😀
(CID:134032141)
Hi Thabo,
Great!, many thanks for the update.
Kind regards
(CID:134032365)
Posted: ‎2020-07-04 10:35 PM . Last Modified: ‎2023-10-22 04:22 AM
