Posted: 2020-07-02 10:58 PM . Last Modified: 2024-04-09 01:16 AM
I have configured my device to email me temperature threshold warnings every 5 minutes for up to 5 times. I saved the configuration, but it sends me emails every 1 minute and it never ends. Am i doing something wrong?
(CID:105462037)
Dear Jason,
I would suggest you to verify if you have enabled correct Severity levels. In case if you have enabled Informational event as well, you may get an email alerts.
I would suggest to verify the settings to see if the settings as per your requirement.
If repeat at an interval of 2 minutes and until condition clears, you will get an email alerts every 2 minutes until alarm clears.
I also request you to make sure that the Netbotz 200 appliance firmware is the latest version. This K-base document can help you to upgrade the firmware of the appliance.
K-base ID: FA156047
http://www.apc.com/site/support/in/en/faq/
(CID:105462041)
Posted: 2020-07-02 10:58 PM . Last Modified: 2023-10-31 11:45 PM
