Posted: 2020-07-02 10:21 PM . Last Modified: 2024-04-09 01:29 AM
(CID:105460389)
Posted: 2020-07-02 10:22 PM . Last Modified: 2024-04-09 01:29 AM
Hi everzosa, thank you for posting. Let's see who can be of assistance here. Meanwhile, @community - any ideas? Best, Stine
(CID:105460606)
At some point I did see an option to configure a proxy (not NAT) but as I recall it didn't have any user auth so I'm not sure how useful it would be. If there's a feature request to add support for DCO client/server comms through gateways (proxy & NAT) , I have +2 customers to add Cheers
(CID:105460639)
Hi Elmer,
I'm really sorry to disappoint you, this might not be the 'answer' you are looking for, but I would like to share with you that this will be partially solved with the next release and tenant portal. Further enhancements expected to be implemented in later versions.
Kind regards
(CID:105460702)
Posted: 2020-07-02 10:22 PM . Last Modified: 2024-04-09 01:28 AM
I also have a customer who is requiring that DCO be hosted on a private LAN and must use NAT to communicate with a corporate LAN IP address. Is there currently a work around to allow client communication that we could attempt?
(CID:106203219)
Hi Brian, We have a similar feature request, registered some time ago - If I could have the customer name (by direct email), then I will add it to the existing case, thanks. Kind regards
(CID:106203317)
Hi Ed, Please email me the customer names, then I will add them to the exciting case, thanks. Kind regards
(CID:105460703)
Posted: 2020-07-02 10:22 PM . Last Modified: 2023-10-31 11:44 PM
