Posted: 2020-07-02 10:21 PM . Last Modified: 2024-04-09 01:29 AM
(CID:105460387)
I'm not sure if you will like this idea but we had something similar for a client where he was giving all data from Automation server on Modbus TCP. We created a customized register inside Automation Server for PUE and set the formula inside the AS. From there we pulled the PUE inside DCE as a normal register and were able to trend it , log it and report it in any format we wanted...
(CID:105460395)
This idea will make AS busy or not? Same reading as PUE dashboard.
Any other way, to extract to excel?
thks
(CID:128068205)
Posted: 2020-07-02 10:21 PM . Last Modified: 2023-10-31 11:05 PM
