Posted: 2020-07-05 05:28 PM . Last Modified: 2024-04-03 03:21 AM
I am trying to find the sensor ID of a specific sensor in DCE so I can call it using SOAP but it doesn't seem to be in any of the columns. Is this a value I need to assign or am I looking in the wrong place?
To clarify I need the ID to use in the following field:
Thank you
(CID:140708326)
Hi Neil,
First, you need to have the ID for the device. The following SOAP request should get you a list of devices discovered on your DCE server.
http://
Your response should be a sequence of
Once you have that, you can use this next SOAP request to get a list of sensors for a given device:
http://
Your response should be a series of
Hope this answers your question.
Glenn Martin
(CID:140708356)
Hi Neil,
http://
http://
Glenn Martin
(CID:140708356)
Hi Glenn,
Thank you for the quick response. This was exactly what I was looking for.
Appreciate it
(CID:140708366)
Posted: 2020-07-05 05:28 PM . Last Modified: 2023-10-22 04:19 AM
