Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-04 04:54 PM . Last Modified: 2024-04-05 12:05 AM
After associating DCO device with it's DCE counterpart (AP7753) which is an ATS, I then try to save my changes, I get the following
"The system was unable to save your changes due to an unexpected error.
The client will restart and any unsaved changes will be discarded."
I have tried with different ATS, same issue, I am able to save any other kind of association fine.
(CID:130099368)
Hi Russell,
I've tested this moment ago (using DCO 8.2.2) without any problem.
What is the version of your DCO? I was wondering perhaps the modeled ATS device in DCO might contain some unexpected configuration (such as power configuration). So you might want to (as a test) try using the device from Genome Library (without changes) and see how it goes?
Kind regards
(CID:130681241)
Hi Russell,
Kind regards
(CID:130681241)
You are correct, when I use the default genome it works perfectly, I guess going forward we will need to make associations and then connect the power last.
Thanks Jef.
(CID:131958822)
Hi Russell,
My pleasure & many thanks for the update,
Kind regards
(CID:131958825)
Posted: 2020-07-04 04:54 PM . Last Modified: 2023-10-22 04:19 AM
