Posted: 2020-07-05 01:22 PM . Last Modified: 2024-04-04 12:34 AM
Seems like the DCE is not running apache struts but which is the web service used in version 7.5.0?
Our customer ran an application and detected the DCE's web service as Apache.
We require a way to guarantee that apache struts is not associate to the running web service on DCE
(CID:134688866)
Dear Andres Cordero,
That's right, the latest version of DCE-7.6.0 uses Apache HTTP Server 2.2.15.
More details about the packages used in DCE-server can be found on special page Software packages in StruxureWare Data Center Expert (unfortunately this page has not been updated for a long time and therefore is no longer relevant ☹️.
With respect.
(CID:134689003)
The version 7.5.0 use the same Apache HTTP Server 2.2.15. version that 7.6.0?
(CID:134689039)
Yes of course, DCE-7.5.0 use the same Apache HTTP Server 2.2.15.
With respect.
(CID:134689702)
Posted: 2020-07-05 01:23 PM . Last Modified: 2024-04-04 12:33 AM
Hi Andres Cordero and spezialist,
The Software packages in StruxureWare Data Center Expert page has been updated. Thanks for pointing out that it needed attention.
Best,
Jackie
(CID:134695849)
Ok, thanks for the update.
(CID:134695873)
Please, tell us if you could solve this question or not?
With respect.
(CID:137103378)
Posted: 2020-07-05 01:23 PM . Last Modified: 2023-10-22 04:18 AM
