Posted: 2020-07-05 11:56 PM . Last Modified: 2024-04-02 11:45 PM
Hi Community,
Can anyone help me to fetch data from Data Center Expert through API's using what tools? and procedure.
Any guild will be highly appreciated.
(CID:152080615)
Hello Shaik
SOAP is probably the most common tool used to manually query a DCE server using its API's.
Assuming you can view the page I pasted below, the bottom section of this page describes how to make a general call from SOAP to DCE when verifying sensor data.
https://sxwhelpcenter.ecostruxureit.com/display/DCIMDEVELOPER/DCE+Sensor+Mapping+to+DCO
Regards
Greg Sterling
(CID:152080629)
Posted: 2020-07-05 11:57 PM . Last Modified: 2024-04-02 11:45 PM
Hi Shaik,
All the documentation that's available is located here:
Look under the links marked:
Web services APIAlarms service methods
Device group service methods
Device service methods
Sensor service methods
There are tutorials on-line, I've found one here:
https://www.guru99.com/soapui-tutorial.html
SoapUI is one of the tools you can use to work with this API
https://en.wikipedia.org/wiki/SoapUI
Steve
(CID:152080639)
Posted: 2020-07-05 11:57 PM . Last Modified: 2023-10-22 04:18 AM
