What is the difference between DCE & DCO?
  • EcoStruxure IT forum
  • What is the difference between DCE & DCO?
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-05 06:33 PM . Last Modified: ‎2024-04-03 02:57 AM
4068
(CID:141269687)
  • Data Center Operation
Posted: ‎2020-07-05 06:34 PM . Last Modified: ‎2024-04-03 02:57 AM
4068
Hi Genjua,
Sorry for the very late response. I will try to answer those 7 questions:
1-  If you have/need modeling a usual data center then you might go for "DCO license", but as a colo provider you might need the colo functionality such cage creation, customer association with racks/cages, etc. then you might go for "DCO Colo license".
2- Licenses are rack based! so there is no limitation on number of created cages and/or users.
3- "One mobile application license is for single user?" This is not clear for me, but as mentioned above, licenses are rack based! so only the number of modeled racks would be counted.
4- I think some users/customers using "Store Room" in DCO as a sort of inventory management. However, via ETL integration interface it is possible to integrate with ServiceNow.
5- For PUE calculations, currently two options available: a) creating a simple PUE b) configuring Energy Efficiency PUE (requires Energy Efficiency license)
6- Currently (in DCO 8.3) with the basic license it is possible to integrate with Cisco UCS Manager (as external system).
7- HP uCMDB integration can be done via ETL integration interface in DCO. And currently with the basic license it is possible to integrate with HP OneView (as external system).
PS: please start with a new community post/case if you should have more questions 😀  thanks.
Kind regards
(CID:143755046)
Replies 10
Dear Muhammad Genjua,
As described on portal https://ecostruxureit.com/all-solutions/:
MONITORING SOFTWARE: StruxureWare™ Data Center Expert - Centralized monitoring, quick resolution of events, vendor neutral.
and
PLANNING AND MODELING SOFTWARE: StruxureWare™ Data Center Operation - Data analysis and modeling, intelligent energy management, airflow optimization, impact analysis, KVM, configurable web portal.
In more detail with the above software, its purpose and pricing policy can be found on the links StruxureWare Data Center Expert and StruxureWare Data Center Operation.
In addition, I advise you to watch a few explanatory videos on the resource Video Tutorials. This will help you understand the purpose of this software.
If you have more questions, please ask.
With respect.
(CID:141269714)
4069
Thanks much for your reply, Yes i have more questions to ask and i will start from Data Center Operations and then move forward to Data Center Operation - Capacity , Cooling Optimize etc.
Data Center Operation:
  1. In the license we have two types of license, Colo License and Simple License, If we have multi vendor or commercial data center we will go with Colo License else go with simple one?
  2. If we order Colo License of 100 racks how many cages we can built? and how many different user can logon with it to monitor their servers?
  3. One mobile application license is for single user?
  4. How we will perform inventory management? Through ServiceNow? We need to order some license to use it?
  5. For PUE calculation it will integrate and pull data from EcoStruxure Power Monitoring Expert?
  6. Cisco UCSTM Manager Plug-in is free of cost or it is paid?
  7. Its library already contain HP uCMDB and OneView integration stuff? is it a part of Data Center Operation – Server Access
(CID:142051338)
Questions about DCO software competently will be able to answer Jef Faridi.
With respect.
(CID:142051351)
Jef Faridi i will be looking forward for your kind answer.
BR
Genjua
(CID:143264682)
4069
Hi Genjua,
Kind regards
(CID:143755046)
Jef Faridi FIrst of all thanks much for one liner and detailed answers.
Further my apology for writing my question in the same post as you asked to open the new post because i feel to clarify my questions related to this post before open the new.
I am asking about mobile applications licenses having part number SFVIZORANDROID23 & SFVIZORIOS43
If I order above part number how many concurrent user can login from their mobile to access DCO?
a) Creating simple PUE - its is included in DCO basic license
b) Configuring Energy Efficiency PUE which means we need to order DCO basic License + DCO Energy Efficiency Module.
Correct?
BR
Genjua
(CID:143755455)
Hi Genjua,
You are most welcome,
concerning 3-
Vizor (SFVIZORANDROID23/& SFVIZORIOS43) is discontinued and replaced by the web client in DCO. Following page contains details about web client:
https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/StruxureWare+Data+Center+Operation+Web+Clien...
Web client (dose not require additional license) is available on a computer, tablet or mobile device with an internet browser.
concerning 5-
That's correct (both a and b)
a) Creating simple PUE included in DCO basic license.
https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/Using+the+PUE+DCiE+Dashboard
b) Configuring Energy Efficiency PUE requires additional Energy Efficiency license being installed.
https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/StruxureWare+Data+Center+Operation%3A+Energy...
Kind regards
(CID:143755534)
One Last Question before i close this post.
concerning 4- Where user is interfacing with "Store Room" Using ETL, is it available in DCO basic license ?
concerning 7- Where user is interfacing with HP uCMDB Using ETL is it available in DCO basic license ?
BR,
Genjua
(CID:143755896)
Hi Genjua,
That's correct in both 4 and 7 - ETL integration dose not require additional license, so available in DCO basic license.
Kind regards
(CID:143755903)
Posted: ‎2020-07-05 06:34 PM . Last Modified: ‎2023-10-22 04:18 AM
