What is ci_type=PowerModule in ETL Export configuration_item
  • EcoStruxure IT forum
  • What is ci_type=PowerModule in ETL Export configuration_item
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 06:43 PM . Last Modified: ‎2024-04-09 01:51 AM
790
Hi
I have a DCO 7.5 SP3 setup with over 100 Symmetra UPSs but there are only 16 power modules in the table, 2 in each of 8 UPSs.  What are these?
ci_type | count
BatteryCabinet | 144
CapacityGroup | 75
Crac | 750
Door | 65
ElectricalRoom | 1
EnvironmentalEquipment | 52
EnvironmentalPowerConsumingEquipment | 7
Epo | 51
FireSuppression | 2
FloorPlan | 1
Folder | 17
GenericDataCenterEquipment | 102
GenericFloorPowerEquipment | 157
GenericRackMountEquipment | 1344
Hacs | 70
InRoom | 13
Layer1NetworkGear | 51
Layer3NetworkGear | 366
Pdu | 314
Person | 1
PowerModule | 16
PowerReceptacle | 2
Pump | 3
Rack | 1564
RackMountAts | 86
RackMountPdu | 6
RackMountPduMetered | 2928
Rdp | 4
Sensor | 71
ServerRoom | 74
Ups | 153
ci_name | ci_parent_id | ci_room_label | ci_location
Power Module 3 | 8cd34658-0b87-40a1-8ccf-32d122a1ae9a | Building 2-Level 1 | UPS B/K/Building 2-Level 1/Development/Hume Campus/
Power Module 4 | 8cd34658-0b87-40a1-8ccf-32d122a1ae9a | Building 2-Level 1 | UPS B/K/Building 2-Level 1/Development/Hume Campus/
Power Module 6 | 2221f16f-6a09-42af-bd0c-dd4c1b6b8ead | Building 2-Level 1 | UPS A/J/Building 2-Level 1/Development/Hume Campus/
Power Module 5 | 2221f16f-6a09-42af-bd0c-dd4c1b6b8ead | Building 2-Level 1 | UPS A/J/Building 2-Level 1/Development/Hume Campus/
Power Module 6 | fdf070d7-682b-4b6b-a7f1-ae29098dd8f7 | POD 37 | UPS A/A/POD 37/Data Hall 5/STAGE 3/Hume Campus/
Power Module 3 | 253046d1-12c2-4937-b181-d93659d132a7 | POD 37 | UPS B/B/POD 37/Data Hall 5/STAGE 3/Hume Campus/
Power Module 5 | fdf070d7-682b-4b6b-a7f1-ae29098dd8f7 | POD 37 | UPS A/A/POD 37/Data Hall 5/STAGE 3/Hume Campus/
Power Module 4 | 253046d1-12c2-4937-b181-d93659d132a7 | POD 37 | UPS B/B/POD 37/Data Hall 5/STAGE 3/Hume Campus/
Power Module 9 | 91016be5-d3a6-4aca-9e0e-890a849cd7ff | POD 5 | UPS B/POD 5/POD 5/Data Hall 1/STAGE 1/Hume Campus/
Power Module 10 | 91016be5-d3a6-4aca-9e0e-890a849cd7ff | POD 5 | UPS B/POD 5/POD 5/Data Hall 1/STAGE 1/Hume Campus/
Power Module 8 | c50db22b-4f8d-4376-8626-ddf189c54049 | POD 5 | UPS A/POD 5/POD 5/Data Hall 1/STAGE 1/Hume Campus/
Power Module 7 | c50db22b-4f8d-4376-8626-ddf189c54049 | POD 5 | UPS A/POD 5/POD 5/Data Hall 1/STAGE 1/Hume Campus/
Power Module 7 | c1217372-3816-4cb9-bed5-372fba506f5f | UPS Room | POD 14&15 UPS-A/UPS Room/Mezzanni Level Stage 1&2- UPS Room/Hume Campus/
Power Module 8 | c1217372-3816-4cb9-bed5-372fba506f5f | UPS Room | POD 14&15 UPS-A/UPS Room/Mezzanni Level Stage 1&2- UPS Room/Hume Campus/
Power Module 7 | 468ce973-71dd-4d55-8520-0cb3ed8f719c | UPS Room | POD 14&15 UPS-B/UPS Room/Mezzanni Level Stage 1&2- UPS Room/Hume Campus/
Power Module 8 | 468ce973-71dd-4d55-8520-0cb3ed8f719c | UPS Room | POD 14&15 UPS-B/UPS Room/Mezzanni Level Stage 1&2- UPS Room/Hume Campus/
(CID:105458006)
  • Data Center Operation
Could they be from a designer import, that included just the two UPSs? We do not currently use them in Operation, but they are captured by the ETL export.
(CID:105458787)
Niels Kjeldsen any idea?
(CID:105458554)
(CID:105458787)
Posted: ‎2020-07-02 06:44 PM . Last Modified: ‎2023-10-31 11:42 PM
