What does SNMP Offer from BO, DCO and DCE?
  • EcoStruxure IT forum
  • What does SNMP Offer from BO, DCO and DCE?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 10:59 AM . Last Modified: ‎2024-04-10 12:41 AM
1104
What information is available from SNMP for DCE and DCO?
Is there a MIB available?
Craig
(CID:94601997)
  • Building Operations
  • Data Center Operation
Replies 6
1104
The MIB can be found on the following link
http://www.apc.com/tools/download/index.cfm
(CID:94602081)
Posted: ‎2020-07-02 11:00 AM . Last Modified: ‎2024-04-10 12:41 AM
Thanks Oscar, and maybe I am not looking in the right place but all I can see there is SFNBMIB410 which is a MIB for Netbotz only.
I was after what MIB (if any) is available for DCO and DCE (and BO).
If I point and SMNP tool I get results but it seems to only be from Linux and not APC related.
Any further clues for what to look for would be great.
Craig
(CID:94602161)
Hi Craig,
For DCO a number of OIDs are exposed. They are mainly OS related but relevant to the DCO application: DCO SNMP Status Codes
For DCE I'm not aware of any other OIDs than what you might find from the general OS. There are some server access configuration that can be done for SNMP in the Server Access menu. These are however used for SNMP communication towards devices SNMP Server tab
For BO I'm also not aware of any OIDs other than the OS specific once.
(CID:94602123)
DCE and DCO SNMP MIB Information should be under powernet.mib, which is same MIB file for the most of APC devices.  Latest file of PowerNet.mib version should be v4.1.4.
You can find the same link as above and choose "Firmware Upgrades - MIB."  This will give you the link to the FTP download site.  Official link is still v4.1.2.
http://www.schneider-electric.us/sites/us/en/support/faq/faq_main.page
About SBO (StruxureWare Building Operation), MIB file is shared on Building Download or Knowledge Exchange Page
https://ecobuilding.schneider-electric.com/
https://community.se.com/t5/Building-Automation-Knowledge/tkb-p/knowledge-base_public
I could only find the direct MIB file link of SBO in here.
https://community.se.com/t5/Building-Automation-Knowledge/Testing-SNMP-alarms/ta-p/1393
(CID:94602524)
You are also able to forward SNMP traps from DCE to another server. You can choose the severity level for the traps sent. Then I believe you need to load the powernet.mib in that client to read the traps.
Look under "Alarm Configuration" then "Network Management System Integration".
(CID:94602529)
Posted: ‎2020-07-02 11:00 AM . Last Modified: ‎2023-10-31 11:42 PM
