Posted: 2020-07-03 04:12 AM . Last Modified: 2024-04-08 11:43 PM
Hi All,
I am searching for an IP camera (probably Pelco) that can be installed outdoors, needs to be:
I have seen the supported list on this site, but it looks like most of those have been discontinued.
Is there an up-to-date compatibility list available, or does anyone have any experience or has installed similar before?
David
(CID:106209390)
Hi David!
Here is info from knowledge base:
The initially supported Pelco cameras from version 3.x firmware are:
Pelco Camera Model | Product Family | Firmware Version Tested |
IP3701H-2 | IP | Unavailable |
IP110-CHV9 | IP110 Camclosure® | Unavailable |
SD4N-W0 | Spectra Mini IP | Unavailable |
The following is a list of cameras and Pelco firmware that has been tested with BotzWare version 4.0. The Sarix line of Pelco cameras have been added to testing:
IXS0C | Sarix IX | 1.7.19.9080-A1.5842 |
IXE20DN | Sarix Enhanced | 1.7.19.9081-A1.5843 |
IX30DN | Sarix IX | 1.7.8.9080-A1.5288 |
IMSOC10 | Sarix IME | 1.7.41.9260-O2.6725 |
SD4N-W0 | Spectra Mini IP | 1.2.15 |
With the release of Botzware 4.2, the following list of additional Pelco cameras and firmwares have also been tested:
IMSOC10 | Sarix | 1.8.2 |
IM10C10 | Sarix | 1.8.2 |
IX30DN | Sarix IX | 1.8.2 |
D5118 | Spectra HD | 1.8.2 |
TXB-N | Spectra IV IP | 1.8.2 |
DD4N-W0 | Spectra Mini IP | 1.2.15 |
IP110 | IP110 Camclosure® | 1.0.47 |
IP3701 | IP | 1.0.10 |
The following is a list of cameras and Pelco firmware that has been tested with BotzWare version 4.4:
Pelco Camera ModelProduct FamilyFirmware Version Tested
IM10C10 | Sarix | 1.9.2 |
IMS0C10 | Sarix | 1.9.2 |
D5118 | Spectra HD | 1.9.2 |
IME119 | Sarix Enhanced | 2.1.2.0.8280-A0.0 |
Just in case, do you consider weatherproof analog camera and CCTV pod (NBPD0123) for Netbotz as an option?
(CID:106209536)
Thanks for your reply Valentin. I also had a reply back from Matt at Pelco / Schneider, unfortunately it seems that most of these cameras are now obsolete. The only remaining compatible camera is the Sarix IL though this isn't weatherproof. Is the NBPD0123 still available? - I thought this analog converter was a part of the original Netbotz range. If it is still available, then perhaps this could be an option for a generic camera instead...
(CID:106209756)
Yes, it's from Netbotz V2 generation, but still available for order as I know.
(CID:106209783)
Still appears on the APC web site as available. http://www.apc.com/shop/uk/en/products/APC-NetBotz-CCTV-Adapter-Pod-120-with-USB-cable-16ft-5m/P-NBP...
(CID:106210004)
Posted: 2020-07-03 04:12 AM . Last Modified: 2023-10-31 11:42 PM
