Posted: 2020-07-02 01:35 PM . Last Modified: 2024-04-09 04:29 AM
Energy Meters connected to PME fail to report more data than Peak/Avg Current & power such as KWH, KVar, KVah in DCO even if the meter is capable to report. Here is the information received in DCO from the meter when a meter is mapped from PME in DCO:
(CID:98304057)
Similar is observed in case of BCPMs & FMPDUs, which are capable of displaying data more than the displayed data & critical parameters which are not usually displayed in DCO when integrated. Is there a way of capturing these data within DCO?
(CID:98304064)
Hi Aniruddha,
DCO only supports measurements for power in Watt and Ampere.
It is not possible to get or use kWh in DCO.
(CID:98664477)
Posted: 2020-07-02 01:35 PM . Last Modified: 2023-10-31 11:42 PM
