WEBMIN not working...
  • EcoStruxure IT forum
  • WEBMIN not working...
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 08:17 AM . Last Modified: ‎2024-04-10 01:33 AM
2212
We have recently installed Struxureware DCO. While configuring the port 10000 was used for Webmin configuration, but recently owing to some internal network policies port 10000 is used for some other network requirements and no more allowed to use the same. The result is now when we try to open up Webmin it shows PAGE TIME OUT message. Rest Struxureware DCO client works perfectly fine.
Is their any way we can check whether our WEBMIN service is running ok or not using some other means?
Is their any way we can change webmin port  from command prompt?
E
(CID:89555032)
  • Data Center Operation
Posted: ‎2020-07-02 08:18 AM . Last Modified: ‎2024-04-10 01:33 AM
2210
Hi Vineet,
              Please use the below mentioned command in the command prompt to check the webmin service running or not.
Command:
root@operations:~# service webmin
Usage: /etc/init.d/webmin { start | stop | restart }
root@operations:~#
root@operations:~# service webmin status
Webmin (pid 1738) is running
Command used to check the webmin pid
root@operations:~# ps -eaf | grep webmin
root      1738     1  0 Jul30 ?        00:00:19 /usr/bin/perl /usr/share/webmin/miniserv.pl /etc/webmin/miniserv.conf
root     31367 28433  0 08:57 pts/0    00:00:00 grep webmin
Hope this helps
Satish
(CID:89555058)
Replies 10
2211
Hi Vineet,
Command:
root@operations:~#
Hope this helps
Satish
(CID:89555058)
Satish, the idea is to change the Webmin port from 10000 to let's say 10079 while the Ops is already running, so what is the command to change that?
(CID:89555059)
Why don't we have option of changing Webmin port, when we configure the server first time at root prompt or initial configuration screens or perhaps I may have overlooked?
(CID:89555060)
2210
Hi  Vineet,
To change the default Webmin port from 10000 to xxxxx, all we need to do is
Login to webmin page
Click on Webmin > Webmin configuration > Ports and Addresses > change 10000 to xxxxx?
Satish
(CID:89555062)
Satish, I believe you never read my query correctly..Issue is we are not having access to Webmin at all owing to port block that is the reason why this query has come up...
(CID:89555064)
2210
Hi Vinteet,
              To change the webmin port from command line using this following command.
command
root@operations:~# vi /etc/webmin/miniserv.conf
Here change the port number of webmin and restart the service.
I Hope this answers your question
Please let me know if you still face any issues.
Satish
(CID:89555067)
Satish, can you attach snapshots for this since I have tried getting to root and shooting VI with this command but nothing happens...Is it because of 7.4 version since in 7.4 we have to get inside sudo mode to run services...
(CID:89555096)
Posted: ‎2020-07-02 08:18 AM . Last Modified: ‎2024-04-10 01:32 AM
2210
Hi Vinteet,
Using Satish description you should be able to change the port. However please note that we do not officially support changing port on the services we rely on, and during future upgrades, firewall changes etc. you might experience issues.
You could also use SSH Port forwarding to get around the port blocking. There's plenty of guides on google on the subject. Here's a few that works on Windows:
http://howto.ccs.neu.edu/howto/windows/ssh-port-tunneling-with-putty/
http://www.cs.uu.nl/technical/services/ssh/putty/puttyfw.html
Mads
(CID:89555074)
Posted: ‎2020-07-02 08:19 AM . Last Modified: ‎2024-04-10 01:32 AM
Vineet, is the DCO server IP shared with a network device? Can you be a bit more specific.
(CID:89555100)
Posted: ‎2020-07-02 08:19 AM . Last Modified: ‎2023-10-31 11:42 PM
