Posted: β2020-07-05 08:48 PM . Last Modified: β2024-04-03 01:05 AM
Hi team,
Customer had the following question:
This vulnerability was identified because (1) jQuery 1.11.1 has reached its end-of-life and is no longer supported by the vendor, consider upgrading to a newer supported version
OpenSSH: Brute-Force Authentication Protection Bypass Vulnerability
OpenSSH: Untrusted Search Path Vulnerability
OpenSSH: Shared Memory Manager Privilege Escalation Vulnerability
OpenSSH: Password Length Limitation Denial of Service Vulnerability
OpenSSH: Security Bypass Vulnerability
The above is solved in OpenSSH version 7.9p1 or higher,
What version do we have in DCE 7.7
(CID:147196454)
Posted: β2020-07-05 08:49 PM . Last Modified: β2024-04-03 01:05 AM
Hi Cees de Vogel,
Security scan results are listed here: https://sxwhelpcenter.ecostruxureit.com/display/UADCE725/Security+fixes+in+StruxureWare+Data+Center+...
CVE-2015-5600 and CVE-2016-1908 are included, the others are not. Engineering will have to search prior scan results to give you a definite answer.
Best,
Jackie
(CID:147197147)
Hi Cees,
When I queried sshd in DCE 7.7.0, it returned:
OpenSSH_5.3p1, OpenSSL 1.0.1e-fips 11 Feb 2013
Can you please provide a link to a web site or CVE showing the reported vulnerability to which you are referring?
(CID:147196560)
Hi Steve,
Here the requested CVE information:
CVE-2015-5600
CVE-2016-10009
CVE-2016-10012
CVE-2016-6515
CVE-2016-1908
BR
Cees
(CID:147196997)
Thanks...I'll see if I can find anything from the engineering teams.
(CID:147197142)
Hi Steve,
Thanks for your response, check also answer Jackie,
BR
Cees
(CID:147197160)
Hi Cees de Vogel,
Best,
Jackie
(CID:147197147)
Hi Jackie,
Thanks a lot
BR Cees
(CID:147197159)
Posted: β2020-07-05 08:49 PM . Last Modified: β2023-10-22 04:16 AM
