We Value Your Feedback!
Could you please spare a few minutes to share your thoughts on Cloud Connected vs On-Premise Services. Your feedback can help us shape the future of services.
Learn more about the survey or Click here to Launch the survey
Schneider Electric Services Innovation Team!
Posted: 2020-07-04 10:47 PM . Last Modified: 2024-04-04 02:46 AM
Hi Team,
Customer ran a vulnerability scan on his network and did find the following on DCE & DCO, it all has to do with a update of OpenSSH to a version 7.7p1 or later.
DCE = 7.5 & DCO = 8.2.2
In which version of DCE/DCO will this be updated ?
(CID:134026904)
Hi Cees,
. The current suggestion I can make and what we’re asked to do for customer is to note:
And that
Steve
(CID:134027416)
...Very interesting, but even the most recent official updates for RHEL-7.5 (and for CentOS-7.5) offer a vulnerable version of OpenSSH:
$ uname -a
Linux 3.10.0-862.11.6.el7.x86_64 #1 SMP Fri Aug 10 16:55:11 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
$ rpm -qa | grep ssh
openssh-server-7.4p1-16.el7.x86_64
openssh-7.4p1-16.el7.x86_64
openssh-clients-7.4p1-16.el7.x86_64
libssh2-1.4.3-10.el7_2.1.x86_64
(CID:134027175)
hmm, interesting ...
(CID:134027218)
Hi Cees,
And that
Steve
(CID:134027416)
Thanks Steve, I will contact the customer to sent their vulnerability report to the email address mentioned above.
Cees
(CID:134027427)
Posted: 2020-07-04 10:48 PM . Last Modified: 2024-04-04 02:46 AM
Hi Cees,
Here is a brief summary of our responses to the vulnerabilities highlighted within the underlying packages installed on DCE 7.5. A follow on post will do the same for DCO.
CVE-2016-1908 and CVE-2015-5600 are both addressed within DCE 7.5 as it uses a newer version of openssh (openssh-5.3p1-123.el6_9.x86_64), which contains fixes for both.
The other 3 issues are not technically fixed in our shipping version of openssh, as fixes are not available on CentOS 6, but they are generally not exploitable and/or can be mitigated by a user. Details below on that below:
It's worth noting that fixes are available for these issues within CentOS 7. DCE will move to this version in a future release, likely within 2019.
Please let me know if you or your customer have any follow on questions or concerns and we'd be happy to answer them.
Brian Behbehani
(CID:134028283)
Hi Brian,
Thanks a lot for your clear answer, will sent this info to the customer.
Will wait for the response on DCO,
Best regards,
Cees
(CID:134028503)
Hi Cees
As Brian Behbehani mentioned fixes are available for these issues within CentOS 7, Data Center Operations 8.2.2 is shipped with CentOS 7.4 and openssh packages that are installed contain fixes for mentioned vulnerabilities.
OpenSSH packages that are installed with Data Center Operations 8.2.2 are
openssh-server-7.4p1-13.el7_4.x86_64
openssh-7.4p1-13.el7_4.x86_64
openssh-clients-7.4p1-13.el7_4.x86_64
Please see here for updated packages that contain vulnerability fixes https://access.redhat.com/errata/RHSA-2017:2029
You are more than welcome to contact us if you have any follow up questions.
Regards
Elvedin
(CID:134028629)
Hi Elvedin, thanks a lot for your response,
Best regards,
Cees
(CID:134028632)
Posted: 2020-07-04 10:48 PM . Last Modified: 2023-10-22 04:16 AM
