Unable to load room
  • EcoStruxure IT forum
  • Unable to load room
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 06:00 PM . Last Modified: ‎2024-04-09 02:07 AM
784
Unable to load room
We have just installed DCO and made some changes to a room. However since then, the rooms are not loading - in particular the room labelled "Nevda".
Attached below is the log files from the DCO server
logs-144_203_106_230_at_11-25-15 (1).tar.gz
(CID:104863383)
  • Data Center Operation
783
Hi Mate,
We have investigated the log files and the issue you experience has been resolved in our latetest service pack SP3. The issue is a rack-mount PDU on the power path in a storage room. There is a bug in DCO 7.5 where the client cannot handle this situation.
Please download and install the SP3 service pack.
Here is a link to the service pack: http://updates.apc.com/swo/downloads/version/NCE3U31/sp3.cfm
In the patch folder you will find a sp3.txt file with installation instructions.
Jesper
(CID:104863434)
Replies 4
Hi Mate, Is this a problem on all the clients connected to the DCO server? One quick thing to try is to un-install one of the DCO clients and re-install it again. This will cause the information from the server to be re-downloaded to the client. We will investigate the logs and get back to you. Thanks Jesper
(CID:104863393)
784
Hi Mate,
Jesper
(CID:104863434)
Hi Jesper,
Thank you for the quick response. SP3 installation went smoothly which completely solved our problem.
Great support and DCIM community.
Rgds,
Mate
(CID:105456593)
Posted: ‎2020-07-02 06:00 PM . Last Modified: ‎2023-10-31 11:39 PM
