Unable to create ETL export database
  • Unable to create ETL export database
129
72
Posted: ‎2020-07-04 02:08 PM . Last Modified: ‎2024-04-05 02:43 AM
1314
I get the below error when trying to create an export internal database.  Can you advise how to resolve this?
database.
(CID:128755521)
  • Data Center Operation
Replies 6
What version of DCO?
(CID:128755605)
DCO version 8.2.0-73742-ee8a6. Module version 1.6.
This is a demo server environment setup by our sales contact for us.
(CID:128755893)
Posted: ‎2020-07-04 02:09 PM . Last Modified: ‎2024-04-05 02:43 AM
1314
Hi Lai Yuan,
Use another etl user name, it seems you are using an existing user name (in the system).
I guess you might have done the following:
  1. created an export data base (such as "test2"), with etl user name "test2"
  2. deleted export configuration name (such as "test2")
Note: configuration can be removed, but the created etl user will be in the system (not removed).
3. if I go ahead, and create an export data base, using existing etl user ("test2"), then I would get the similar failure/error:
However, if I use another/not existing etl user name (such as "test2xnewuser"), then the data base creation is successful:
Kind regards
(CID:128756110)
Thank you, I can create the database now using test2xnewuser.  A feature request would be to list down those existing users that cannot be used or remove them from the system altogether if the database is deleted.
(CID:128762906)
Hi Lai Yuan,
You are most welcome, sounds great that using another etl user have resolved the issue.
I have now registered your feature request to list the existing etl user(s) - I will also send you a direct confirmation as well, thanks.
Kind regards
(CID:128762926)
Posted: ‎2020-07-04 02:09 PM . Last Modified: ‎2023-10-22 04:09 AM
