Posted: 2020-07-03 01:22 PM . Last Modified: 2024-04-08 01:39 AM
Is it possible to model the power path upstream of a UPS in DCO? I am attempting to model the power path from utility/generator to ATS to main power panel that feeds UPS and AC units. However, in the UPS itself there is no Power Dependency section that allows me to specify the power panel and breaker the UPS gets its power from.
(CID:112625974)
Hi Michael D'Angelo, thanks for posting. Lets see who can be of assistance here. @community any ideas?
Kind regards Ditte
(CID:113642025)
Hi Michael,
You are right, modeling a power path upstream of UPS is unsupported in DCO, currently the supported power path is from UPS -> PDU -> rack pdu and/or floor mounted devices.
However, in your example/power path: 'Generator-x' -> -> -> UPSx -> AC
As a workaround, perhaps (in DCO) you might want to try to model a UPS unit instead of 'Generator-x' and a PDU unit instead of 'UPSx'.
Kind regards
(CID:113642300)
Is there a plan to add power path functionality upstream of the UPS as well as including a generator as a power source?
(CID:130096321)
Hi Rob,
Not in near future, however your feature request is captured in our system, thanks.
Kind regards
(CID:130681656)
I'm still looking for a rack mount UPS under 8kva genome for 8.1 that actually supports a power path. Any ideas?
(CID:131959233)
Hi Mark.
Your feature request already captured i think at but sadly no new feature yet AFAIK. Perhaps its in the works?
Cheers
Ed
(CID:131959247)
We are now able to login via the Web Interface for HP OneView using a HP OneView "local" account. We still get the same error. Is there a way to specify the domain to be local? I've tried "local\username".
(CID:131960029)
Hi Rob,
I guess wanted to post the comment in another post (HP OneView "The External System returned an error").
Kind regards
(CID:131961492)
Posted: 2020-07-03 01:23 PM . Last Modified: 2023-10-22 04:08 AM
