Why are Work Orders from DCO 8.0.4 not showing in Portal 1.3.6?
  • Why are Work Orders from DCO 8.0.4 not showing in Portal 1.3.6?
127
65
Posted: ‎2020-07-03 01:21 PM . Last Modified: ‎2024-04-08 01:39 AM
559
Running DCO 8.0.4 and Portal 1.3.6.  Other metrics appear to be pulling, such as rack utilization.
Portlet for Work Orders shows:
The following error was encountered while reading data for this portlet:
Unmarshalling Error: Not a number: NOT_STARTED
Contact your local support representative.
(CID:112625932)
  • Portal
Hi Tim,
It seems you are right, currently in Portal 1.3.6 the Work Orders portlet is not working - apparently a bug needs to be fixed in one of the future versions.
As a work around, you might want to use the "Data Center KPI", it contains work orders as Available KPI Types:
Kind regards
(CID:112626107)
Posted: ‎2020-07-03 01:21 PM . Last Modified: ‎2023-10-22 04:21 AM
